configure iqagent server
configure iqagent server [vr [[vr-name | none] | [ vr_name vlan vlan-name]] | ipaddress [fqdn | ip_address| none]]
Description
Configures the optional user-defined virtual router (VR) and address for the server for ExtremeCloud™ IQ Agent to connect to.
Syntax Description
iqagent Specifies configuring IQ Agent.
server Specifies configuring IQ server.
vr Specifies selecting a VR for IQ server.
vr-name Specifies the name of the VR.
none Specifies no user-defined VR. Auto-discovery is used instead (default).
vlan Specifies which VLAN to run on.
vlan-name Specifies the name of the VLAN.
ipaddress Specifies configuring a server address
fqdn Specifies a fully-qualified domain name for IQ server.
ip_address Specifies an IP address for IQ server.
none Specifies using auto-discovered information from IQ Agent discovery (default).
Default
By default, if no VR is specified, the VR is auto-discovered.
By default, for the server address, auto-discovery is used.
Usage Guidelines
To view IQ Agent information, use the command show iqagent discovery.
The following example configures connecting to IQ server on VR "VR-Mgmt":
# configure iqagent server vr VR-Mgmt
The following example configures connecting to IQ server at the address 134.141.1.1:
# configure iqagent server ipaddress 134.141.1.1
The following example unconfigures any user-defined changes and returns to auto-discovery:
# configure iqagent server none
This command was first available in ExtremeXOS 30.7.
The vlan option was added in ExtremeXOS 32.1.
Platform Availability
